Adding aux input to factory radio - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-23-2013, 05:51 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Found this CPFD20AUX3.5 1998-2007 Ford Auxiliary Input Converter Kit w/3.5mm Dash Mount Kit and thought it was pretty slick. Looks like it comes with RCA cables. Could an amp and subs be hooked up??
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 2 Old 07-23-2013, 11:27 PM
alaskan155's Avatar
Quoted: 65 Post(s)
why not just invest in a aftermarket deck? most give you usb/AUX input and pre-outs for subs.
and looks like its just inputs so you can hook you mp3 player, or etc and play it threw the factory deck
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
