CB/Air horn/cup holder ?s - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-10-2013, 06:35 AM Thread Starter
bfitch's Avatar
so in between doing engine mods to my truck, i want to do some small things to the interior. i want to mount a CB in the ceiling where the Temp display would go. i also want to put in an air horn but with a pull chain instead of a switch. any ever do either of those and have any tips? how hard is it to take down the roof lining to run cables, and im guessing you just screw it right into the body? also, i cant find and pull chain switches, is that something you have to make up or does someone sell them.
one more thing, are the cup holders from 99-05 (or whenever then changed the SD body style) all interchangeable? my cup holders suck and i was to get the ones that have the bottom that drop down.
E99 F250 SD 7.3 ECLB 5in exhaust, intake, built trans, WW2, T500 HPOP, mechanical wastegate and a custom tune. more to come
bfitch is offline
post #2 of 12 Old 07-10-2013, 08:21 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
1) The CB you will have to pull the headliner down and find the crossmember and drill into that because otherwise you will drill through the roof to the outside. The problem with this is since yours is an ext cab i think the only way to fully pull the headliner out you have to remove the front seats or remove the rear window so you will have to work with it hanging there. Its do-able just a pain in the arse.
2) Wolo Manual Truck Air Horn Lanyard Valve for On-Board Air Systems
Thats the one i was gonna use before i decided i like the electric solenoid better to save me from running air lines into the cab
3) The cupholder from 99-2000 sucked so most guys swap for the 01-04 style works much better, but good luck finding one because they are getting rarer to find unless you buy from the dealer(big $$$) i have one for sale but im selling as a bulk deal with a bunch of dash pieces.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 12 Old 07-10-2013, 08:22 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
they are not! I have very good prices on these cup holders!
2000-7.3L is offline
post #4 of 12 Old 07-10-2013, 08:23 AM
Chapter Director
Quoted: 5 Post(s)
Your also not a "dealer" per-say but if he wants new your probably the cheapest
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 12 Old 07-10-2013, 08:24 AM
2000-7.3L's Avatar
im not a dealer
post #6 of 12 Old 07-10-2013, 08:28 AM
Chapter Director
Quoted: 5 Post(s)
im not a dealer
But you do DEAL parts
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 12 Old 07-10-2013, 09:49 AM Thread Starter
bfitch's Avatar
you have to take the front seats out or the rear window to take out the headliner? holy crap!
2000-7.3, what do you get for your cup holders?
bfitch is offline
post #8 of 12 Old 07-10-2013, 09:52 AM
Chapter Director
Quoted: 5 Post(s)
Yes sir and i heard its a tight fit you gotta bend it a bit without creasing it. just be glad you can do that us guys with CCs only can pull it through the back window. Pulling the seats isnt really that big a deal just four bolts holds each in and unplugging the connector underneath they arent that heavy either
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 12 Old 07-10-2013, 09:56 AM Thread Starter
bfitch's Avatar
What's behind the headliner? Is there sound dampening in there? If I got real ballsy and was ok with a hole in my headliner, would I be able to cut one in and see enough to find the cross member?
bfitch is offline
post #10 of 12 Old 07-10-2013, 10:00 AM
Chapter Director
Quoted: 5 Post(s)
Nothing is behind it just your roof and a few crossmembers, what you do is take off everything that holds the headliner up and that lets it drop and you can see whats under there and you could figure out where you can mount it. Thats how I(like alot of guys) installed cab lights, i wasnt gonna pull the rear window
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
