New console and dash completed - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-09-2013, 08:31 AM Thread Starter
bulldogsf350's Avatar
Here it is guys, Finally worthy of posting a picture of the dash and console I just built. Just took some of you guys ideas, threw in mine and this is what I came up with.
bulldogsf350 is offline
post #2 of 23 Old 07-09-2013, 08:33 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Can you take a close up of the gauge pod?
2000-7.3L is offline
post #3 of 23 Old 07-11-2013, 02:22 PM
Eco Taxi's Avatar
thats nice, would def like more and closer pictures. maybe some explanation on what you started with and howd you end up there
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #4 of 23 Old 07-11-2013, 05:12 PM
y2kf350's Avatar
^^^^ me too!
2000 F350 CC 4x4 Dually
Lots of stuff done - lots more to do.
y2kf350 is offline
post #5 of 23 Old 07-12-2013, 08:18 PM
Joel's Avatar
Quoted: 10 Post(s)
Subscribed
Not the greatest pic, but so far i like what i see
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 23 Old 07-13-2013, 07:17 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I love the console that goes all the way up to the dash like that. Better pics would be great and info on how you did it like the others said!
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 23 Old 07-13-2013, 06:30 PM Thread Starter
sorry for the poor picture guys, just figuring out the uploading in here.
here is where I started.
I started off with the basic "skeleton" then wrapped it with fleece from walmart to get the shape, coated it with fiberglass resin. While it was still wet I also laid on chop mat to help keep it from pulling and warping. after that has dried added several more coats of chop mat to make it thicker to keep it from flexing from the JL 12W7 ;-) once that is dried lots of body working with dynaglass and rage gold. once smoothed out a couple coats of slicksand sprayed on to give it the final layer before either paint of vinyl wrap
post #8 of 23 Old 07-13-2013, 06:33 PM Thread Starter
post #9 of 23 Old 07-13-2013, 06:36 PM Thread Starter
on the gauges I got the idea from someone in here to use 2" pvc pipe and couplers for the rings. I used the pvc glue to glue the to each other. as you can see I had to cut out the 2 vent, turn the vertical and mold them back in with abs pieces in the openings. I disassembled the 10" screen and took the bezel and glued it onto the dash, then wrapped it with the same fleece and went from there
post #10 of 23 Old 07-13-2013, 06:38 PM Thread Starter
This is the guts of the xbox 360 that I had to take apart to put the dvd drive in the console. I had to order extension cables off of e-bay for the drive. I also had to disassemble the power switch to mold it into the new radio bezel. the electronics had to be modified. ( You Tube is your friend for this)
The next few is where I had to pull the dash out to dye it charcoal to match the vinyl that I got to match the seats. and a before picture of the sound deadening and then with the hushmat
