2003 F250 Lariat overhead console - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-01-2013, 04:31 PM Thread Starter
Quoted: 3 Post(s)
Have searched the forum for a couple hours looking for this. Mine is not working-no display. I assume the resistors are loose.
Problem is I can't figure out how to get it out. That is, the overhead console. I pulled it down and it dropped maybe an inch or less and that's as far as I can get it to go. The black part stays up on top of the headliner. On the back of it appears to be a part of it that goes up inside the sheet metal, and that appears to be holding it. I'm not sure how to get it apart?
Everything I've seen in the forums is for the '99-'01 that has the single compartment. Mine is the style that has two separate doors on it if that makes any difference.
junkyardwarrior is offline
post #2 of 2 Old 07-03-2013, 06:10 PM
BSkopnik's Avatar
When I pulled mine it was a bit of a pain. I thought I was going to break it but eventually it finally popped off. The retaining clips were just doing a heck of a job holding it up. My lariat is the same, two doors.
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
