Need power - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-26-2013, 05:47 PM Thread Starter
Redlazer's Avatar
Need power
OK my Truck is manual everything. I want to add power windows, power doors locks with keyles entry. What would be the best way for me to go?
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 3 Old 06-26-2013, 10:52 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I am currently in the same position. I'll tell you, it will be much much easier to buy aftermarket stuff.
If you want to do it with factory stuff, I would get real friendly with a local junkyard, or do what I did and by a parts truck. Everything runs through the computer.
I now have to decide if I just swap the entire harness or do all the cutting and splicing.
One option I considered, was get aftermarket stuff, and factory switches, then it would look factory when completed
schlutzer is offline
post #3 of 3 Old 06-27-2013, 08:13 AM Thread Starter
Redlazer's Avatar
The question is how good quality is aftermarket stuff. I have factory switches already
CAROLINA GRAY BOY
Redlazer is offline
