Alternator pigtail=flashing battery dash light? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-18-2013, 12:47 PM Thread Starter
Hi guys and gals- 2001 F350 7.3 with a battery light that flashes intermittently, and/or steadily on. I read it could be wiring, pigtail, or alternator itself causing this. I looked at my 3-slot plug to alt to see it only has two wires that feed into it, but the new pigtail I saw at the store has 3-wire feed. Any advice on flashing battery light? Thanks!!
RafterQ is offline
post #2 of 5 Old 06-18-2013, 01:02 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
If it's been on there a while, it could just be going out.
I had one where the bearings started failing and it was 'slowing' down. I had belt rubber on the pulley where it was skidding on the belt from time to time.
I drove my truck on the alternator for about 6 years before it gave it up. Unfortunately, they do just fail sometimes. As to the pigtail, I think mine only has two wire in the plug.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 5 Old 06-18-2013, 01:08 PM Thread Starter
Thanks. Were you having the intermittently flashing bat light too?
RafterQ is offline
post #4 of 5 Old 06-22-2013, 09:17 AM
clcruce's Avatar
Garage
I had the same problem, reseated the connectors and made sure everything was tight. Havent had a problem since then.
Chris
E99 F350
AFE Two Stage Cold Air Intake, 5" MBRP Exhaust, Edge CTS (system monitor), PHP Hydra Chip, HPx
[/URL]
clcruce is offline
post #5 of 5 Old 06-22-2013, 12:41 PM Thread Starter
Thanks, Chris. Guess that's my next step. Nice lookin' rig, BTW. (Looks alot like mine)
2001 F350 Lariat 7.3L 4x4 CC SB
BFG-AT 35x12.50R16.5, 4" Lift 173,000mi...so far
RafterQ is offline
