Disabling instrument dimming - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-16-2013, 08:14 AM Thread Starter
I drive with my headlights on, all the time, as a matter of company policy.
That makes it hard to read the overhead display and such, since they dim when the headlights are on.
Is there a way to insert a switch that would disable the dimming function, so I can avoid that during daytime?
Or is there at least a good wiring diagram available somewhere, so I can figure it out, myself?
BrownianHeatingTech is offline
post #2 of 3 Old 06-16-2013, 08:31 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Yes, there is.
There is a wire you can cut that signals it to dim, but idr which one and I don't have the link anymore. Someone cut it and then put in a switch to reconnect it if you wanted to use it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 3 Old 06-16-2013, 02:32 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Here's a good Gauge Installation page (#32 on second page) -> Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
As jesilvas says, just disconnect the side they tell you to tap into for the gauge illumination and supply it with battery voltage (gonna be right there on the back of the switch, just on the supply side of the rheostat there)
NoRalPh is offline
