Can u hook up OBD2 to a touch screen stereo - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-02-2013, 10:44 PM Thread Starter
bronco73's Avatar
I would like to view my trucks gauges though a new touch screen stereo. Can this be done, and if so what do I need? Thanks guys.
bronco73 is offline
post #2 of 10 Old 06-29-2013, 12:44 AM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Feedback Score: 3 reviews
im gonna this up cause this would be awesome if it were possible!
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #3 of 10 Old 06-29-2013, 02:08 AM
Macon's Avatar
Short answer, no.
Long answer, yes. It would just require someone to get into the stereo firmware, and create a new version with all of the code needed to translate the PCM output into something you can read. After that happens (without destroying the radio portion of the firmware), a new GUI would need to be created so that the radio can display all of this new information. Once all that tricky smart man stuff is done, the OBDII port would have to be adapted to something the stereo can use, such as a USB. That's easy enough, and creating the drivers needed isn't complicated for someone that can do the rest of the stuff above.
An alternative to all of that would be things already on the market. Edge, DP Tuner, or even a blue tooth OBDII dongle and appropriate app for an iPod.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 10 Old 06-29-2013, 02:15 AM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
And there you have it!
If I'm not mistaken, banks has a tuner/radio/nav unit/gauge combo..... Is that correct?
Bully Dog intake
post #5 of 10 Old 06-29-2013, 02:18 AM
JSchuricht's Avatar
The simple way of doing that is to use the radio as a video display for something like a Autoenginuity.
JSchuricht is offline
post #6 of 10 Old 06-29-2013, 02:19 AM
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Or that...
Bully Dog intake
post #7 of 10 Old 06-29-2013, 02:23 AM
Macon's Avatar
Then you run into problems to power whatever the AE is on. Since it's supposed to be electrically separated from the vehicle power, you can't just plug it in to the cigarette lighter.
2002 F250 CCSB 4x4
Macon is offline
post #8 of 10 Old 06-29-2013, 02:37 AM
JSchuricht's Avatar
Then use a optically isolated USB adapter or wireless adapter for the AE.
post #9 of 10 Old 06-29-2013, 02:41 AM
Macon's Avatar
I'm talking about for charging what AE is loaded on. No matter what it is, it needs charged. It can't be charged off the vehicle system or something or another horrible can happen.
2002 F250 CCSB 4x4
Macon is offline
post #10 of 10 Old 06-29-2013, 02:47 AM
JSchuricht's Avatar
The issue is feedback from the vehicle power through a laptop through the AE and back to the PCM. If you isolate that at some point like the USB connection then the loop is broken and you are free to charge it off the vehicle power. There are solutions similar to this in use, often they use bluetooth between the OBD II and specific radio's, IIRC Pioneer is one of the brands in use. The issue with those is support for the enhanced commands that would make it useful on a diesel.
