Power window problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-29-2013, 07:58 PM Thread Starter
E99F350Stroker's Avatar
I am currently having multiple electrical issues with my XLT F-350. I'll start with the one that is the most annoying, the power windows. My passenger side window does not work. The window can be rolled up from both the driver and passenger doors, but not down. I know for sure that the window motor is good, and have pretty much narrowed it down to a wiring issue. I'm not sure where to go from here.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #2 of 8 Old 05-29-2013, 09:54 PM
Id say its probably a switch if your sure the motor is good, swap the passenger rear door switch to the front door and see if that does it, If not then I would guess the drivers side switch. I would be really surprised if its a wiring issue instead of a bad switch. If one side of the legs of the switch is worn out and making contact in one direction that would stop it from going in one direction and still let it work in the others and would also stop the other side switch from working
thecoolmankyle is offline
post #3 of 8 Old 05-31-2013, 02:42 AM Thread Starter
My truck is a super cab so I don't have passenger power windows. I think I'll just order a new driver side switch and if that doesn't fix it then it's time to break out the multimeter I guess, always fun lol.
Jordan
post #4 of 8 Old 05-31-2013, 03:24 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
order a set from car-part.com. its much cheaper than new.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #5 of 8 Old 05-31-2013, 05:32 AM
goats's Avatar
Quoted: 2 Post(s)
Pull the switch off and clean with contact cleaner. My buddy had the same issue until I cleaned his switch.
goats is offline
post #6 of 8 Old 05-31-2013, 11:15 AM Thread Starter
I already cleaned the switch with contact cleaner, it still didn't work . I might try cleaning it lightly with emery cloth. I didn't do that last time.
Jordan
post #7 of 8 Old 05-31-2013, 11:21 AM Thread Starter
Ok I'll take a look of cleaning it doesn't work. Btw sharp truck, was it recently in the "readers diesels" section of Diesel Power?
Jordan
post #8 of 8 Old 06-01-2013, 06:49 PM
Doesn't Even Care
Quoted: 69 Post(s)
Yessir. It was all red at that point
Sent from AutoGuide.com App
Nick
"The Mistress"
