Drilling into dash question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-26-2013, 01:31 PM Thread Starter
I want to put some AA mini mag lite mounts in the dash between the radio and the 4x4 switch. I am a little concerned about drilling into that area though, and really don't want to take the dash all apart.
I considered using some type of adhesive, but I'm not sure it would be strong enough. The mounts I have for my D cell mag lite hold the flashlight very snug and it takes a little effort to pull it off.
So I guess I have two questions for anyone that may have done this before....are self tapping screws strong enough? That way I don't have to take the dash apart to put nuts and washers.
And is there any wiring back there that would be in danger of getting hit if I were to screw in there?
Thanks
Pipewrench is offline
post #2 of 7 Old 05-26-2013, 01:58 PM
sprksonu's Avatar
the dash cover pulls off in just a few seconds? put the gear selector in first gear and pull outwards is held in with clips
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 7 Old 05-26-2013, 02:20 PM Thread Starter
This will take the whole piece off around the radio and everything? I'll try it I guess. Just seems like that was a huge section that would probably tough to get off. Thanks
post #4 of 7 Old 06-06-2013, 09:32 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Aside from the headlight switch the whole thing pulls off easy. I also like the D cell mag lights and keep one in each truck in the door pocket or between driver seat and console. However I would find some place better than the dash to mount the holder clips. They force needed to pull off the light would likely dislodge the snap-on dash panel even if you did mount the clips with bolts and nuts. Self drilling screws are gonna pull outta plastic.
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #5 of 7 Old 06-06-2013, 09:37 AM
Quoted: 23 Post(s)
On re-read I realize you ask about AA mini mag not D cell. Mini would likely be ok with sheet metal screws as opposed to self drillers. They will remove less material and screw will fit tighter and hold better. #10x1/2" is what I'd use. Good luck.
Greg
Semper Paratus
post #6 of 7 Old 06-06-2013, 09:49 AM
Macon's Avatar
Pull the dash, use washers to better distribute the pressure. No reason to go quick and easy just to have it rip a huge hole in your dash a year from now. I've pulled my dash off a few times, and it's an easy enough process.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 7 Old 06-06-2013, 10:08 AM
BrianSnelgrove's Avatar
Agreed, the dash panel comes off easily. Pull it off and you dont have to worry about hitting anything and you can see exactly what is behind the spot you are wanting to drill into.
BrianSnelgrove is offline
