Extended cab subwoofer - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-19-2013, 02:03 PM Thread Starter
strokenred97's Avatar
I know this has probably been covered on here before but I couldnt find an exact answer. I want to install a single ten or twelve inch sub. but I dont want to lose all of the under seat space. Is there a decent way to only put it under the drivers side rear? Or is the best option to put one under the front middle seat? Any experience with this setup?
00 Ex Cab LB, 145k Miles, Built 4R100, 4 in exhaust, S&B cold air intake, FRx, PHP Hydra, WW2, Bellowed up-pipes, ISSPRO gauges, 203* thermostat, 305/70/R16
strokenred97 is offline
post #2 of 16 Old 05-20-2013, 03:56 AM
basicbajax's Avatar
If you dont want to lose space in the back the front middle jump seat is the way to go. I have made one that fits under the center seat. It only raised the seat about 2 inches. It's specifically made for a speaker needing .5cu/ft air space. I will have pics tomorrow. I also have 2 more almost made up.
I used to think high mileage was a bad thing, but its a badge of honor on my F250 Powerstroke.
basicbajax is offline
post #3 of 16 Old 05-20-2013, 05:11 PM Thread Starter
yeah I'd like to see some pics if you have em. I have felt around under my middle seat and it just doesn't seem like theres much room for a sub but I haven't removed anything either. It seems like a great place to put a sub though.
post #4 of 16 Old 05-21-2013, 03:49 AM
basicbajax's Avatar
Here is what I have...granted, I am not a carpenter but this is my first try.
post #5 of 16 Old 05-21-2013, 03:51 AM
basicbajax's Avatar
another couple pics
ID:	114505   Click image for larger version
post #6 of 16 Old 05-21-2013, 03:55 AM
basicbajax's Avatar
and the amps...also changing all my light to red led's
ID:	114521   Click image for larger version
post #7 of 16 Old 05-21-2013, 05:33 AM
Njstroker91's Avatar
That looks great I've been wanting to do it like this is .5 cubes pretty much the most you can squeeze I there?
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #8 of 16 Old 05-21-2013, 06:09 AM
basicbajax's Avatar
That is what I am shooting for... I guess you go a little bigger than a half cube. I have been waiting for a new Stereo Integrity MKIV 12 inch sub to finnally go into production. It has small mounting depth and only needs .5cu/ft airspace.
post #9 of 16 Old 05-21-2013, 09:02 AM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
I put mine in between the center console and the rear seat...Lost one spot for someone to sit but for me it wasnt a big deal as normally the dog is the only one in the back seat lol
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #10 of 16 Old 05-31-2013, 05:19 PM
Joel's Avatar
Quoted: 10 Post(s)
I made one similar to the box above, but I deleted the brackets so that I had adequit air space and didn't raise the seat at all.
It's therefore not bolted down as good as stock, so not exactly street legal for someone to sit there...
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
