Gauge cluster died - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-13-2013, 09:23 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Gauge cluster died
I was driving home last night and then all of a sudden i noticed my gauge cluster lighting go out. i had noticed it was really dim lately. I didnt look to see if my window switches went out as well to indicate that its a fuse problem.
I tried the map lights and they worked so its not the switch i dont think that went bad. All the needles still work its just the lighting that died. Anyone had that happen?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 14 Old 05-13-2013, 09:23 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
BULBS BLOW?
2000-7.3L is offline
post #3 of 14 Old 05-13-2013, 09:25 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Not all at once they wouldnt
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 14 Old 05-13-2013, 09:28 AM
2000-7.3L's Avatar
why not? Iv seen 6 bulbs go at once on a cluster?
post #5 of 14 Old 05-13-2013, 09:41 AM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
Maybe the illumination wire is grounding out? You did check the dimmer switch, right? :
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #6 of 14 Old 05-13-2013, 09:57 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Maybe when i was doing my gauges i f-ed something up in there. but yes i did check the dimmer switch Im not THAT stupid...usually
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 14 Old 05-13-2013, 01:12 PM
Quoted: 3 Post(s)
You checked the wire going to the illumination feed on the gauges? I'm guessing you tied into your dash lighting. It can only be that feed or bulbs. Bulbs are much more unlikely. Turn your lights on and jiggle the wire, see if it's loose.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #8 of 14 Old 05-13-2013, 01:15 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yea ill try that tonight like you i highly doubt all the bulbs died simultaneously
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 14 Old 05-15-2013, 07:34 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
BUMP tried jiggling and that didnt do the trick any other suggestions?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 14 Old 05-15-2013, 08:39 AM
Quoted: 3 Post(s)
Do you have a testlight? turn your running lights on and check your hot lead from your light switch to the gauges. Check first behind the panel and then check behind your gauges. If this lead is hot, check your ground. If both of those are fine, then you may have bulb issues.
01 Ex 7.3l Limited
06 headlights
