A/c on defrost fix - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-27-2013, 06:52 PM Thread Starter
A/c on defrost fix
Mu 2000 f250 only blows on defrost the ESOF works and the vacuum pump works think the problems under the dash. Need help
2000_7.3 is offline
post #2 of 7 Old 04-27-2013, 06:54 PM
ZMANN's Avatar
Quoted: 1568 Post(s)
it might be the actuator
u can open the glove box past the norm by pressing in at the stop
the actuator is there
pull the vac hose and change the ac vent selector and feel for vacuum at the hose
We Miss you Ronnie
ZMANN is offline
post #3 of 7 Old 05-25-2013, 05:42 AM
Rebelliousw0n's Avatar
mine has the same problem. i am in the middle of an engine swap and discovered this after a little bit of digging. check the quality of all your lines.
Rebelliousw0n is offline
post #4 of 7 Old 05-25-2013, 05:40 PM Thread Starter
Thanks man where is that located in the picture
2000_7.3 is offline
post #5 of 7 Old 05-25-2013, 07:15 PM
see the main harness in the bottom right? that little bit is mounted to your fender skirt with 1-2 of those little plastic push pins.
post #6 of 7 Old 06-01-2013, 12:48 PM
Powerstroke Techie
Does the vacuum pump run CONSTANTLY? It should shut off once a certain threshold of vacuum is reached.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #7 of 7 Old 06-01-2013, 12:49 PM
In my case with that split in the line I bet it would be.
