Passenger front speaker dead - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-23-2013, 10:50 PM Thread Starter
wick07's Avatar
So it was a nice evening here and I figured I would put my new front speakers in as I have upgraded to a navi head unit and I wanted something better then stock. I removed the factory clips from the speakers and soldered leads on to them so I could attach the new speakers to the factory plug, I dummy rigged it to make sure that I had positive and negative right and turn on sound and for about 30 seconds I was rocking I moved it a little and it cut out, now I tested speaker on other side and it works so I know I didn't blow the speaker but now my wiring is not working on the front passenger door and don't have any blown fueses ??? Help
wick07 is offline
post #2 of 6 Old 04-24-2013, 11:14 PM Thread Starter
wick07's Avatar
No ones had a problem with door wiring or door harness problems?
wick07 is offline
post #3 of 6 Old 04-24-2013, 11:21 PM
JSchuricht's Avatar
You need to figure out where the break is. Often it will be where the connection is. Hook up your speaker and start wiggling the wires around till you find exactly where it looses signal and repair it.
JSchuricht is offline
post #4 of 6 Old 04-25-2013, 10:48 AM Thread Starter
wick07's Avatar
Well as i was checking last night now my passenger window doesnt work either, door locks do but nothing else
wick07 is offline
post #5 of 6 Old 04-25-2013, 02:57 PM
JSchuricht's Avatar
In that case you need to look for a commonality between the connections. I would focus on the connection between the door and cab, it's located behind the kick panel.
post #6 of 6 Old 04-25-2013, 03:05 PM Thread Starter
wick07's Avatar
thank you, look when i get home from work
wick07 is offline
