multiple little electrical annoyances - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-20-2013, 12:55 AM Thread Starter
Rodslinger's B1TCH
sometimes i turn the key on and the power windows and stereo don't work. i figured out that if i slap the dash a couple of times they will start working which leads me to believe there is a loose connection. is this common at all? where is the loose connection?
my hvac blower fan also started working at low speed on all setting except for high speed which works as it should. switch? resistor block?
the off delay on my auto headlights got really long one day. it used to take about 30 seconds or less for the lights to shut off, now it's about 5 minutes... not sure exactly but it's long enough that my neighbour calls me to tell me i left the headlights on after i come home.
steve604 is offline
post #2 of 6 Old 04-20-2013, 09:23 AM
Joel's Avatar
Quoted: 10 Post(s)
I have no words or wisdom for the first two issues, but I would pull the fuse for the running lights.
The fuse only controls the DRL's and could be replaced at any time. Beats draining batteries and wearing out headlight bulbs all the time.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 6 Old 04-24-2013, 09:11 PM Thread Starter
Rodslinger's B1TCH
the auto headlights are the least of my worries. the stereo/window problem is the one that bothers me most right now.
anyone else?
steve604 is offline
post #4 of 6 Old 05-01-2013, 07:09 PM
Joel's Avatar
Quoted: 10 Post(s)
Radio and windows stopped working...
Have you seen this one yet?
Joel is offline
post #5 of 6 Old 05-02-2013, 01:47 AM Thread Starter
Rodslinger's B1TCH
Thanks, some interesting reading there.
It looks like most people go a long time using the dash smack method which I think I'll stick with for a while. There doesn't seem ti be a good fix for that.
steve604 is offline
post #6 of 6 Old 05-15-2013, 11:07 PM
meangene81's Avatar
I have this problem as well just not as bad its temperamental and was worse when it snowed or rained. What I have found out is that my windshield was leaking. I fixed that with a new windshield. But unfortunately Ford placed the GEM module or (body control module) in the wrong area, and it got wet, when that happens all hell breaks lose in the truck. So I would check that out first Rock auto has them for a decent price, Ford has refurbed ones for around 800 installed. They do need to be programmed for your truck.
Good luck
Hope this helps
meangene81 is offline
