2004 King Ranch Seats in a 2000 F350 - Wiring Help Needed - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-07-2013, 11:30 AM Thread Starter
adobai's Avatar
Does anyone know how to wire 2004 King Ranch seats into a 2000 F350 Lariat? Is there anything I need to worry about to do a bench test and figure out the firing myself?
adobai is offline
post #2 of 9 Old 04-08-2013, 04:06 PM
350factor's Avatar
Do you have any wires under your seat now? Were your previous seats powered?
vvvSold the truckvvv
'03 7.3 F350
6637 Mod
Foil delete
'05 Front end conversion
F650 Lower dash
34"Tires
3"Lift
Visited "EARTH ROAMER" shop down the road from my family.I want,I like,I'll build my own(Family trip to Alaska and South America)
"LET GOD JUDGE OUR ENEMIES, I JUST SET UP THE MEETINGS"
350factor is offline
post #3 of 9 Old 04-08-2013, 04:33 PM Thread Starter
adobai's Avatar
The driver's side has a powered seat stock. The passenger seat is manual.
adobai is offline
post #4 of 9 Old 04-08-2013, 05:08 PM
350factor's Avatar
You should be able to replace the seat with the newer one and connect. If the plugs are different its just a three wire (power/ ground/ and a smaller gauge wire which I believe is to sense wether you have your seat belt plugged in or not). Since you don't have a passenger seat hook ups, you might be able to just run some jumper wires from the driver side connection power and ground since it is already fused from the battery.
'03 7.3 F350
6637 Mod
Foil delete
F650 Lower dash
34"Tires
3"Lift
post #5 of 9 Old 04-08-2013, 05:14 PM Thread Starter
adobai's Avatar
Thanks for the quick help 350factor! The part I can't wrap my head around is where to plug the jumper wires from my factory plug into the new seat harness. This thing has a bunch of wires.
adobai is offline
post #6 of 9 Old 04-08-2013, 06:11 PM
350factor's Avatar
Take a picture of the underside of the newer seats. Are the connectors still there? Have the connectors been clipped off? Take a picture, we can find out what wire controls what motor and then ultimately figure out what wires connects to the truck itself. Also does your newer powered seat have anything extra besides tilt, forward/back, up/down. Like heated seats?
'03 7.3 F350
6637 Mod
Foil delete
F650 Lower dash
34"Tires
3"Lift
post #7 of 9 Old 04-08-2013, 06:20 PM
Ive done this to my 2000 f250. Its cake. 350factor is right it is only 3 wires that you need to worry about. I am not by my truck right now but when I am I will look for you. It is SOOOOO easy so don't stress it little buddy. Just tap into your drivers wires, run it under the carpet and you'll be good to go. Ill look at the wires on my truck and tell you the exact color. I don't get on the forum that often though so If you want a fast reply text me. 801-682-0201
2000 ford f-250 leveled off, crew cab, headlight upgrade, gauges; pyro, boost, tranny. 6637 intake. 06 lariat dash/seats/interior. DP tuned. A dash of this, a dash of that
Motormorgan is offline
post #8 of 9 Old 04-10-2013, 04:58 PM
350factor's Avatar
Any word on getting your seat installed and wired?
'03 7.3 F350
6637 Mod
Foil delete
F650 Lower dash
34"Tires
3"Lift
post #9 of 9 Old 04-28-2013, 12:20 PM
E99F350Stroker's Avatar
Yeah, how did it go? I might do this with my seats.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
