dads 01 seat belt warning issue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-04-2013, 09:33 PM Thread Starter
my dad has a 01 xl extended cab with the bench front seat ( idk if that matters) anyway its seat belt dinger is possessed, one day it will never go off at all the next it goes off even if you connect every seat belt in the truck. he already pulled the wires out of the drivers side (they were exposed) twisted em together and tapped it up but that didnt stop it. any ideas?
1996 F-250 crew cab 5 speed
diy intake 4in dp back exhaust
gauges and ts 6 chip
ClutchKick512 is offline
post #2 of 2 Old 04-05-2013, 04:43 AM
Redlazer's Avatar
OK man just unhook the seat belt connector under the seat. That is what I did on mine. The dash light does not come on and the dinger will not make a sound.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
