Clicking sound upon start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-03-2013, 04:40 AM Thread Starter
KellerMAC's Avatar
I have a 2001 F-250 7.3 Powerstroke and I have a intermittent clicking sound when I turn the key to start the engine. If I turn the key off and restart, the sound goes away. Sounds like it is behind the dash. Any thoughts?
Also, I have a buzzing sound sometimes following a hard rain. It causes the dome light to flicker on and off and the only way I can control it is to roll the dome light switch to 'on' position and the buzzing stops. Once the truck is dry, then the problem subsides.
Thanks,
Keller Mac
KellerMAC is offline
post #2 of 6 Old 04-03-2013, 04:42 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
if im not mistaken the PCM module is getting wet. not for sure im no 7.3 expert but i know its pretty common on them. im sure someone can chime in where the leak is. i think windsheild?
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #3 of 6 Old 04-03-2013, 04:47 AM Thread Starter
KellerMAC's Avatar
Thanks for your reply.
Where is the PCM located on my 2001 F-250 7.3 PS?
Thanks
post #4 of 6 Old 04-14-2013, 09:19 PM
mcyrana's Avatar
batteries. if your batteries drop below a certain voltage relays start clicking on and off. i had that problem but my starter was the problem since it was weak and drawing too much power
im not sure about the rain problem though but your pcm is located in the lower left of your firewall. Look behind your parking brake and you will see it
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #5 of 6 Old 04-19-2013, 11:56 AM
yep , Batteries. I just put 2 new ones in my 99 PowerStroke.
my other rides
6SPEED is offline
post #6 of 6 Old 05-01-2013, 11:35 PM
SUCIO's Avatar
Im having the same clicking noise only while cranking. Turns over great and starts every time but I cant figure out where that clicking noise is coming from.
1999 F-350 7.3L, 4x4, AT ,6.0L Cooler, 4" Pinnacle Performance straight pipe exhaust, Warn locking hubs, Edge Juice w/attitude monitor for gauges, SCT SF3 Tuner, BD Billet Wheel, 4" Lift kit, 35x12.50x17" Nitto Trail Grapplers with 17" x 9" Unique Soft 8 wheels, DIY Tymar intake, Zoodad mod
SUCIO is offline
