Radio won't turn on with truck
So I've been having a problem with the radio in my truck since I bought it in September. It started with about once a week it would just turn off for a few mins when cruising down the road. Then it would do it once and a while. And when I would drive in rainy weather it could go on and off non stop sometimes. Then it went to just a delayed turn on when I turned on the truck. Maybe a minute at most after cranking the truck over it.would turn on. And if I tuned the truck on and off and on it would start right away sometimes. Now. It won't turn on until about 20 miles down the road. Sometimes not at all. Bumps in the road have no effect. Today I drove 10 miles. Parked it and left if running. It turned on while parked. When it turns on I hear a relay click. And sometimes the dash flashes the 4x4 low range ses and abs lights. Maybe some other lights to. And.on top of this. Sometimes the.power windows won't work while the radios off also...... so after that long story. Any ideas what could be causing this? And idk if it matters. I got my amp gauges and cb all running off the remote turn on lead. I have a good ground. And.a good fuse. But no power to the wires behind the radio. I was thinking maybe a bad relay? Just not sure where to start. Thanks in advance. And the radio works fine. Bench tested it today just to check.
Sent from my VS930 4G using AutoGuide.Com Free App
