Keyless entry upgrade
Hey, my truck is a lariat with electric locks. How hard is it to add a keyless entry system?
I'd like to have a remote to unlock the doors.
You should already have the system in place, all you need is a remote which you can get on ebay pretty cheap. One way to make sure you are set up already, turn your key to 'run' (not far enough to crank the engine) and then back off. Do that 5 times in a row quickly, and leave it on the 5th time. your door locks should lock then unlock. This means you are in the programming stage for the remotes and your set to go. When you get your remotes, do the same thing, after the lock/unlock, press the lock button on your remote and it will program it!
I have them in stock!
4C3Z 14A626-AA
$114.76 List-$159.67 |
SM |
is that for one remote fob?!
horizon ford quoted me something like $60 and that was even to much.SM |
