F350- Fuse/Relay problem - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-04-2007, 04:57 PM Thread Starter
ghhmtnboy's Avatar
I have a 2003 F350 Crew cab diesel, 21K miles.
Power windows and radio are not working. Fine on one day, not working the next day.
Checked radio fuse, it's good. No power in Fuse Panel where 30a circuit breaker for windows clips in.
Noticed two 'fuse' panels under the hood, removed the covers, looks like relays, not sure what I'm looking at, each one is about one inch square.
Can someone offer a suggestion, what do these control?
What I should do next?
Thank you--
ghhmtnboy is offline
post #2 of 14 Old 11-04-2007, 05:20 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Man I wish I could help you as wireing problems can be a major pita. Its still under warrenty take it in to the dealer.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 14 Old 11-05-2007, 03:49 PM Thread Starter
ghhmtnboy's Avatar
Thanks, it's a 2003, don't think warranty still is in force. Appreciate the reply. Like your truck.
post #4 of 14 Old 11-05-2007, 03:52 PM
vitalidle's Avatar
Yep your right! Darn it eh! You could try to trace the powerwire that is dead to the fuse panel and see if you can find the reason for no power.
Auto 93,000 miles
DP Tuner F5
post #5 of 14 Old 12-01-2007, 08:47 AM
guzzle's Avatar
It looks like the only thing in common with the radio and the windows is the Accessory Delay Relay (relay K126 under steering wheel).
I would try swapping it out and seeing if the relay is bad.
02 F350 4x4 SRW EC LB Lariat
guzzle is offline
post #6 of 14 Old 12-15-2007, 03:33 AM
Start with all connections... start from the source to the unit(s).. look for chaffing, loose wires, shorts, pulled apart connections... etc..
Like mentioned above.. major PITA..
"you think you can catch my big scaley butt with that?? Look at me man,, I'm HUGE!"
NCDave is offline
post #7 of 14 Old 09-01-2009, 06:54 PM
Mike Hickman's Avatar
Having same issue what was it which relay.....
TRUCK WAS STOLEN NOW IS SOLD 2006 Lariat FX4 F-350
7" BDS Lift
SCT Xcal3 Tuned By Truck Source Diesel TSD with SPD !
Triple pod Auto Meters
4" MBRP Exhaust
Straight piped Turbo back
Zoodad Mod
325/65/18 13.50's MTZ
18x10 Mickey Thompson Bead Locks
A1 H11 Studs Head Bolts/Studded
EGR Deleted
Harley HeadLights
S&B Intake
Mike Hickman is offline
post #8 of 14 Old 09-06-2009, 07:54 AM
Mine did the same thing yesterday, it was fuse #41, the one for the instrument cluster. By the way, the original post is two years old, I wonder if he ever figured it out?
bigb56 is offline
post #9 of 14 Old 09-08-2009, 08:41 PM
Land Yatch Driver
gygers's Avatar
Mine has been doing the same thing for a couple days now. I will check it out and report back.
Steve
2002 7.3L F350 Lariat 4X4 CC LWB
Auto tranny
ISSPRO Gauges
K&N CAI
Zoodad mod
Tru-cool 40K trans cooler
Walker Big Truck Muffler
gygers is offline
post #10 of 14 Old 09-08-2009, 09:20 PM
I examined the FSM electrical diagrams and I could find no link between the radio and the windows, even though fuse 41 fixed it. I did a search and found this happens a LOT. Most times it is NOT a fuse. I have yet to find a post where, when it wasn't a fuse, it was easily resolved.
One guy said the dealer put in a whole new central junction box. Others have said they could temporarily fix it by smacking the dash just above the radio.
Whatever the issue is, it seems to have to do with the accessory shutoff delay.
Let us know what you find. Did you already check all your fuses?
bigb56 is offline
