Rear power windows stopped.. - Ford Powerstroke Diesel Forum
Old 12-26-2012, 01:17 PM
1999 CC f250.
Both of the rear windows stopped working with in a day of each other. All fuses are good and they will not work off of any of the switches. (Driver or both rear passengers). The 2 front still work.
Safe to assume both the rear motors went out? Anything else I should be looking at?
Thanks for the help.
Old 01-07-2013, 04:31 PM
Nothing? My post is too short
Old 01-07-2013, 04:35 PM
Illiana Chapter Director
Turn the key on, open the rear door and press the window switch down and smack the door panel real hard in a few spots. Sometimes that will make them start to work. If it does, the motors are junk.
Old 01-08-2013, 01:46 PM
Can I just replace the motors or do I need the regulators also?
Old 01-08-2013, 01:51 PM
As long as the regulator isn't damaged then you should be able to replace just the motor.
Old 01-09-2013, 12:54 PM
Makes sense, thank you for your input.
