Beeping noise? Removal of internal speaker? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-26-2012, 07:35 PM Thread Starter
Eco Taxi's Avatar
I have this beeping noise. I know this is a built in speaker that holds specific purposes. I was wondering if anyone knows where this is at? And how to remove it?
Eco Taxi is offline
post #2 of 13 Old 11-26-2012, 07:36 PM Thread Starter
Eco Taxi's Avatar
I have a 2001 f350 7.3
Eco Taxi is offline
post #3 of 13 Old 12-08-2012, 02:40 PM
99TonkaStroke's Avatar
talking about the door dinger that obnoxiously alerts you that you have the door open?
E99 7.3L F350 CCLB
6spd handshaker
cold air intake
straight piped exhaust
6" lift/leveling kit
38 toyos
2013 Ford Explorer-wifes car
'69 Mustang Mach 1. 10+years in the making.
429 & C6...
99TonkaStroke is offline
post #4 of 13 Old 12-08-2012, 02:49 PM
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Someone please explain where it is and I will go rip mine out this very second
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #5 of 13 Old 12-09-2012, 01:31 PM
this may shed some light on what you can do with your warning chime...
specifically the customer preference items. of course this requires a trip to the dealer. I believe the chime is built into the gem.
SM
by
, on Flickr
2000 Excursion Limited 4x4
heated and power everything
7.3 ltr auto
f250 "V" code front and "B" code rear springs
KYB shocks
billet grill
aftermarket headlights
beans chip with;
1: stock
2: high idle
3: economy
4: tow
5: exhaust brake
6: no start
Big Boost
Ford Powerstroke severe duty air intake AIS
WWII
Sticker Monster is offline
post #6 of 13 Old 12-09-2012, 01:39 PM
To kill the door dinger with the key in, remove the under side panel from the steering wheel. There's a wire going to the key. Either snip the wire or unplug it.
For the seatbelt chime, simply disconnect the plug under the drivers seat.
The rest of the warnings, headlights on when not running and the door opens, etc, I don't know how to stop.
Sent from my iPhone using AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #7 of 13 Old 12-09-2012, 02:48 PM
t-ray-4ray's Avatar
Quoted: 89 Post(s)
The seat belt chime is easy on all fords around early 2000s just click the seat belt button when it starts chiming it will go off until you turn the engine off and restart
post #8 of 13 Old 12-09-2012, 05:41 PM Thread Starter
Eco Taxi's Avatar
I have a series of five sets of five beeps ....
I read somewhere that this is because the tunnel area in the middle of the area is damaged (caved in) or something wrong with the air bags - I bought this truck about 6 months ago and couldn't tell then but the truck had front end damage at one time and my air bag doesn't work now on the drivers side and I think the light bulb for the air bag was removed from the instrument panel because the light doesn't come up
I've been slowly fixing all the problems from the previous owner
Does anyone have information on what different series of beeps mean?
Anyone know anything about checking air bags or about this tunnel in the middle of the cab
Eco Taxi is offline
post #9 of 13 Old 01-05-2013, 08:35 PM
floorboy's Avatar
Late post I'm know but in your owners manual is a way to shut off the seat belt minder
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #10 of 13 Old 01-20-2013, 04:59 PM
stroker 250's Avatar
what color is this wire?
stroker 250 is offline
