INSTRUMENT PANEL LIGHTS - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-15-2012, 12:56 PM Thread Starter
MY INSTRUMENT PANEL LIGHTS IN MY 99 CREW CAB WERE NOT ON ONE MORING ON THE WAY TO WORK ,THEN AFTER 20 MIN OF DRIVING THEY CAME ON . THE NEXT DAY THE SAME THING HAPPENED. NOW THEY DON'T COME ON AT ALL. I CHECKED THE FUSES AND THE ARE GOOD ,I WIGGLED WIRES AND CHECKED CONNECTIONS AND STILL NO LIGHTS . ITS JUST THE LIGHTS IN THE SPEEDO/TACH FUEL GUAGE CLUSTER. THE OWNERS MANUAL SAYS TO TAKE TO A DEALER TO REPLACE THE PANEL LIGHT. I'M NOT SURE I WANT TO DO THAT BECAUSE OF THE HIGH COST OF DEALER LABOR. I WAS HOPING SOMEONE COULD OFFER A CHEAPER SOLUTION. THANKS IN ADVANCE
GERBIE53 is offline
post #2 of 5 Old 11-15-2012, 01:34 PM
Quoted: 3 Post(s)
do you have taillights? Mine did the same thing and it turned out to be the fuse, looked good but it was bad. And the gauge lights didnt work and tail lights were off, brake lights still worked though
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 5 Old 11-16-2012, 04:51 AM Thread Starter
THAT'S THE FIRST THING I DID THE FIRST MORNING I NOTICED THE GUAGE LIGHTS BEING OUT, WAS TO CHECK THE TAIL LIGHTS. THEY WERE WORKING SO I HEADED ON TO WORK. I SWAPPED FUSES BECAUSE I HAVE BEEN "BURNED" BY FUSES THAT LOOK GOOD, BUT ARE NOT! I'M GOING TO TRY TO GET TO THE PLUGS ON THE BACK OF THE GUAGE CLUSTER AND CHECK THEM. I WAS WONDERING IF THE POWER TO THE LIGHTS GOES THROUGH A RELAY SOMEWHERE?? THANKS AGAIN!!
GERBIE53 is offline
post #4 of 5 Old 11-21-2012, 07:23 PM
Joel's Avatar
Quoted: 10 Post(s)
Bump. My dads truck hasn't had gauge lights for years.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 5 Old 11-22-2012, 06:43 AM
Turbostang500's Avatar
When I bought my truck (had 376k on it) there was only 1 working light in my dash. I removed the dash and there are about 8 bulbs on the back of it that twist in. Went to Napa (do this cause they have these bulbs in bulk) and bought a hand ful of them. Then replaced all bulbs and good to go!
My suggestions, first, it is kind of a pain to get to. You need to pull the stereo and remove that whole panel. It just snaps in but becareful. You also need to remove the steering column plastics to get the dash panel out. Then, before you remove the dash cluster, cycle your key and watch all your different service lights and such. The key cycle does a bulb test right at first and if you have others that need replacing, now is the time!!! Last, it is just a matter of a few bolts, a couple connectors, and replacing all the bulbs you need to.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
