extended cab back seat size - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-13-2012, 01:09 PM Thread Starter
i have a 99 extended cab dodge and was wondering if an extended cab 7.3 is any larger. needin to fit a car seat in the back is why
06carolinadiesel is offline
post #2 of 5 Old 11-14-2012, 08:36 AM
I don't know if its larger than a dodge but I have a 1 year old and have put his car seat in the extended cab no problem. With his rear facing seat in the middle the top of it comes about 2-3 inches from the front seats. I haven't had an issue with room when trying to turn it to get it out or anything like that. We are switching to forward facing soon and that may be a little different but should be easier. Hope this helps.
99.5 F-250 4X4 S&B Intake, Rosewood Stage 1 Injectors, 4" MBRP Exhaust, and Wildman 6 pos chip
tankrat7.3 is offline
post #3 of 5 Old 11-17-2012, 05:45 PM
I had a 2002 F250 extended cab and the booster seat for my 6 year old was fine behind driver or passenger seat. The car seat for my 3 year old was fine in the middle only. The forward facing seat would fit behind the driver or passenger but then the 3 year old's feet would not fit in the seat, so it stayed in the middle. I had the 40/20/40 front seat with the fold down console/armrest. When we had little boy #3 was when my truck was not big enough. I need a crew cab. Hope this helped.
biscayne is offline
post #4 of 5 Old 11-21-2012, 04:35 PM
cowens726's Avatar
Just visually by comparing the Ford and Dodge extended cabs it looked to me like the Ford had a bit more room, I never measured it just looked like the Ford was a bit bigger. I have had my daughter's car seat in the middle both forward and rear facing and it fit well, getting in and out when rear facing was more difficult but managable. I also have the 40/20/40 front seat so I don't know if that was a help or hindrance. If I remember right most stores, toys R us, babies r us etc. will let you use a display model car seat to put in your rig to check fit. Hope that helps.
Cory
2001 4x4 ext. cab.
cowens726 is offline
post #5 of 5 Old 11-21-2012, 07:14 PM
Joel's Avatar
Quoted: 10 Post(s)
I have a 3 year old and an 18 month old, both forward facing seats.
The trick is to remove the backrest, that gains you like 4 inches when you put the carseat in there. The kids then have plenty of room.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
