Help Please, Autometer Gauge Install - Ford Powerstroke Diesel Forum
Old 08-12-2012, 02:54 PM
I bought an Autometer tri pod that goes over the mirror months ago along with the three basic Autometer boost, trans temp, egt. I am leaving for a long tow trip this week and decided I wanted that in and working.
The main question I have is, Can you install an Autometer trans temp gauge in this overhead pod? The sender length looks too short... If it does fit can you recommend a route that makes it fit and to what location on the trans did you connect the probe?
Thanks in advance!
Old 08-12-2012, 03:15 PM
If it's just the basic sender in the trans where the ground is the trans and only has one wire coming out of it, just get a longer wire.
Old 08-12-2012, 03:21 PM
So I just called and talked with the sales person. I just ordered and electric gauge over night since I had a mechanical. So now I just have to get in and I should be all set. I just have to look back and find where it goes into the transmission.
Thanks
