Have a few problems that need fixed - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-29-2012, 04:57 AM Thread Starter
I've been letting the little problems build up over the past few years, I need to catch this stuff before the truck turns into a complete POS. Any and all advice is appreciated. Truck is an early 99 F-350 dually 4x4.
1. Passenger side window not working. I replaced the switch about an hour ago, now I have up but not down on the passenger switch, nothing from the drivers side.
2. Speedometer quit a few months ago, not a clue there. It was acting funny for a while, sometimes not working, now I have nothing.
3. Heat controls quit, both the temp settings and the selector to tell it where to get air from. I believe this is a vacuum issue? Any ideas on where to start tracing the lines from?
Thanks for the help, I need to get this truck sorted out.
jules083 is offline
post #2 of 16 Old 07-29-2012, 04:59 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Possibly a speed sensor? Idr where it is
I'd check the vacuum pump. On top of passenger side fender.
Replied to what I could
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 16 Old 07-29-2012, 05:05 AM Thread Starter
Thanks. I went to auto zone for a speed sensor, they didn't know where it was either. There was a few of them listed, not a clue which one I have or where any of them are.
Vacuum pump is a good idea to check. Guess I'll start there and begin tracing lines. I read on here somewhere that the heat controls and the front hubs run the same line, but there's nothing going to my hubs so I'm thinking that was either ripped out or blocked off somewhere along the line.
jules083 is offline
post #4 of 16 Old 07-29-2012, 05:30 AM Thread Starter
Ok, looked at some stuff and realized a few things.
Window still doesn't work. Put a volt meter on it, there's power coming to some wires, but I'm not sure which ones should have power?
I think I figured out the speed sensor, a new one is $22 so I'll just change it and see what happens.
vacuum pump. Umm... I have one, what's it supposed to do? I turn the key to on and nothing happens, there's no power going to it. Does something tell it when to turn on, or maybe something in the wiring is bad?
jules083 is offline
post #5 of 16 Old 07-29-2012, 06:12 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You should here the pump buzzing
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 16 Old 07-29-2012, 07:28 AM Thread Starter
Nothing. No buzzing, I unhooked a vacuum line and nothing happened, no power going to it, no blown fuses.
Any ideas?
jules083 is offline
post #7 of 16 Old 07-29-2012, 04:55 PM Thread Starter
Still no ideas?
jules083 is offline
post #8 of 16 Old 07-29-2012, 05:29 PM
Guns & Powerstroke's
HillClimber350's Avatar
Does it blow out defrost all the time?
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
post #9 of 16 Old 07-29-2012, 06:04 PM Thread Starter
Yes, and it's also on cold all of the time.
Last year I was able to adjust temperature, but not that doesn't work either. The heater core is working properly, and I am able to manually move the temperature selector from behind the dash and get heat to come out.
jules083 is offline
post #10 of 16 Old 07-29-2012, 07:46 PM
All of those are ran by vacuum pump.
