Over head compass,temp and mpg screen - Ford Powerstroke Diesel Forum
Old 07-08-2012, 09:09 AM
Hey gang, we had a couple supper hot days here in mn and now my over head monitor doesn't wanna work. Anyone have a similar experience? Got a fix or know where to get a new one?
Sent from my LS670 using AutoGuide.Com Free App
Old 07-08-2012, 10:30 AM
is the screen blank?
Old 07-08-2012, 10:45 AM
Yeah, it just won't turn on. I got it to a couple times by tapping it
But it won't come on on its own
Old 07-09-2012, 06:14 PM
I have a 99 F350 and it had the same problem. The chips on the circuit card come loose. Here is a link on how to fix them, it was easy but you will need a soldering iron.
1999 Ford F350 4x4 - Overhead Console Repair
Old 07-27-2012, 11:05 AM
If the chips aren't loose, then it's likely the pins for the connector. The solder joint on the card is weak, and a quick solder job repairs it. If it is the chips, be careful of how long you keep the soldering iron touched, as some chips are more susceptible to heat damage than others. The proper way is with a heat sink on the back side of the chip.
Old 07-29-2012, 09:02 AM
had the card out chips seemed fine, played with connector came on and went back out after I put everything back together
Old 07-29-2012, 07:35 PM
Sounds like you have a problems with the pins like Macon said.
Old 08-03-2012, 05:40 PM
I found a guy on eBay that repairs them. For around 30 bucks mine works again.
Old 08-24-2012, 06:23 PM
Does anybody know how to change the screen color?
Old 08-24-2012, 07:23 PM
Yep, but it's a trade secret.
