A/C blower issue?.? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-04-2012, 04:46 AM Thread Starter
derek_davis77373's Avatar
A/C blower issue?.?
Could use some help if anyone can. I have a 99 f350 and having some issues with my air volume from my ac. Blows ice cold but does not blow hard. When I change the speed intervals it does speed up but not like it should and changes just fine between defrost floor and vent and fresh air and recirculate. Has a brand new blower motor and I put on a new vacuum pump and seemed to help it a little bit but not much. Any help would be appreciated as I live in Houston and it's already June :/ . Keep in mind it's a 500k mile truck
derek_davis77373 is offline
post #2 of 2 Old 06-25-2012, 04:45 PM
is the blender door broken? and check to see if the blower motor is turning in the correct direction. i replaced mine and had the same issue and found out i had it wired wrong.
wattser322 is offline
