vacuum problems???? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-31-2012, 10:14 AM Thread Starter
Quoted: 17 Post(s)
Feedback Score: 3 reviews
vacuum problems????
i had to use 4x4 today and noticed that once i twisted the knob to 4hi that the ac quit blowing on vent and moved to dash. i have changed to warn lockouts(don't think it matters, but trying to give all info i can). also, 4lo has never worked on my truck.
any ideas?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 6 Old 03-31-2012, 10:17 AM
107stroker's Avatar
Quoted: 2 Post(s)
For the 4lo prob I would check the plug on the transfer case for corrosion . May have a vacuum leak at pump.
107stroker is offline
post #3 of 6 Old 03-31-2012, 12:05 PM
Turbostang500's Avatar
Let me try and follow, you changed the hubs to "manual?" Warren hubs?
you DO have a vacuum leak if your heater doors go to defrost. That is the default setting.
if those hubs are manual then you can unplug the vac lines and cap them. If they are auto hubs then you likely have a seal that is leaking in the hub.
Yes the 4lo is something different and likely the connector, but possibly the shifting motor.
Don't you have to put the truck in neutral to get it in 4lo? Not sure if this is true or your doing it.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #4 of 6 Old 03-31-2012, 05:26 PM Thread Starter
Quoted: 17 Post(s)
yes changed to manual hubs. i didn't do anything to the vacuum lines. do they need to be plugged.
i have been putting it in neutral. i will pull the plug and check it
post #5 of 6 Old 03-31-2012, 05:33 PM
Well they dont have to be unless you develope a leak around a hub seal. At that point they still don't "have" to be plugged but the vac leak would need taken care of.
It is my understanding that most guys who switch to manual hubs, do so because of vac problems and just do away with the system and plug the lines.
This is probably your cheapest route.
Lee
[/URL]
post #6 of 6 Old 03-31-2012, 06:06 PM
107stroker's Avatar
Quoted: 2 Post(s)
Yes plug the lines
