Auto down - Ford Powerstroke Diesel Forum
Old 03-25-2012, 11:04 PM
Auto down
Can i replace the window button on the drivers side, for the passenger side window with an auto down button. WOW!Confusing……can I install an auto down button for the passenger window, D@M still doesn’t sound right LOL. I want (2) of the same auto down buttons driver and passenger 02 f-250
Old 03-26-2012, 05:02 PM
There's more to it than just the window switch. Not sure if it is controlled by the gems or just a relay but basically the switch picks up a relay which is held on until something senses that the window is all the way down dropping out the relay. What senses the window is all the way down could be a micro switch or torque switch.
Old 03-26-2012, 05:34 PM
Try it
But like the coot said, it's probably not just in the switch. Other relays and switches control the auto feature.
Old 03-26-2012, 06:09 PM
I may be wrong but i think the relay is the same. I think it's the switch and the window regulator that control the auto down feature. The only part of the switch that is different is the auto down one has a third position, up, down, and extra click down(auto feature) Im almost sure i read that somewhere on another ford forum, but don't hold me to it..
Old 03-26-2012, 06:19 PM
Well it'd be cool if you could.
Old 03-26-2012, 06:24 PM
agreed. give us an update if you decide to look into it
Old 03-26-2012, 06:26 PM
Not sure about that but you can get a module from DEI called a 530t this would allow auto up and down on two windows
Old 04-17-2012, 07:31 AM
Any word on the auto down
Old 04-19-2012, 06:48 AM
I just had a window switch apart this morning. There are 2 circuit boards inside the switch that work in conjunction with the rocker switches. There are only 6 wires on the one I had apart. It's a 2 door 2003 F250. If there is no wiring for the auto down in the passenger door, I doubt if just adding a switch would help.
