Seat swap? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-15-2012, 04:15 PM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
Seat swap?
Alright. did a search came up with a little info but just wanted to see if anyone has done this.
The seats in my 02 are in decent shape but as anal as i am ive been looking into a newer seat swap. I like the material, feel etc better. Plus i like the rear fold out metal tray option on the 05+ truck. Ive been looking and have come across a 2010 rear seat. I am just curious as to if the front and rear benches would be a direct swap into my truck. I have an xlt with power driver/pass seat.
I saw a guy that swapped 11' kind ranch seats into an 06 so im assuming 1999-06 trucks should be the same.
Possibly different wiring setup? any help would be
slowcoupe is offline
post #2 of 8 Old 03-15-2012, 11:21 PM
All 99-2012 seats will fit. However I cannot speak for wiring.
TreySpooner65 is offline
post #3 of 8 Old 03-23-2012, 07:01 PM
I'm in the same boat too! My driver seat is so wore out my wife can't see to drive anymore! I think there is some difference in the rear seats, might have to get some hardware from Ford. Where are you getting "new" seats? I'm having a heck of a time, and might just go get mine re-upholstered!!
mkfan17 is offline
post #4 of 8 Old 06-09-2012, 12:53 PM
bumping this up...
to be clear...i can swap anything from 99-2012 into my 03 crew cab and it will fit? i need gray leather as mine is an XL model
is the wiring for the power seats somewhere in the truck? i didnt know how far the factory went as far as wiring. i am going to put carpet in the truck.
jshallen is offline
post #5 of 8 Old 07-18-2012, 01:55 PM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
Yes you can swap in any year seats. I ended up picking up a set of power front and rear bench seats from an 07 and got them installed. The front lined up perfect. The rears i had to drill 2 additional holes because the 99-04 rear bench in a one piece bench where as later years it splits as a 06/40 bench that folds up. Wasnet very hard to do though. I just sourced factory bolts with the rubber coating over the heads that way it would match since you see them. Drilled a hole in the floor and used a nut on the underside of the truck to secure. Took less than an hour to swap all the seats in.
2000 Regular Cab SHORTY truck.
-7.3/ZF6 combo.
-TS tuned
-5" exhaust to 7" single mitre.
-DJM 3/5 drop
-22" wheels wrapped in 305 nitto 420's
COMING SOON
-Midwest shifter
-DP tuner
-2008 F350 CCLB ZF6 truck. Leveled, 22's w/37s, deleted, H&Stuned etc -SOLD
-2005 F350 CCLB 6" 37's, studded, tuned etc-SOLD
-2002 F350 CCLB 6"lift, 20's w/35's, DP tuner etc -SOLD
-2005 F250 CCLB 8", 20's w/37's bunch of mods -SOLD
-2002 F250 CCSB 4" lift,18's w/35's DP tunes etc -SOLD
post #6 of 8 Old 07-18-2012, 04:21 PM
chrgd2000's Avatar
Is the wiring the same?
--7.3
chrgd2000 is offline
post #7 of 8 Old 07-18-2012, 06:22 PM
I just swapped an entire 2006 interior into my 2000 this last weekend. dash and all. wiring harness IS different for power seats but they didnt change the color coding of them so I simply spliced them and all the power works great. very simple.
2000 ford f-250 leveled off, crew cab, headlight upgrade, gauges; pyro, boost, tranny. 6637 intake. 06 lariat dash/seats/interior. DP tuned. A dash of this, a dash of that
Motormorgan is offline
post #8 of 8 Old 07-20-2012, 04:58 PM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
Not necessarily. My power seats wring just snapped together like factory. Fully functional
-7.3/ZF6 combo.
-TS tuned
-DJM 3/5 drop
COMING SOON
-Midwest shifter
-DP tuner
