Door question - Ford Powerstroke Diesel Forum
Old 03-15-2012, 02:27 PM
Door question
Hiw do you remove the door panell in a 01 regular cab
Old 03-15-2012, 02:35 PM
1. You need to remove the black wedge looking piece in the front corner of the window.
2. Lift up on your switch plate. There is a screw in the panel behind it about even with your door lock button (if you have door locks) - Unscrew it.
3. Remove the reflector/lens thing near the bottom of the door - There is a screw behind that. Unscrew it.
4. Lift up on the door panel. You will need to unplug the switch panel.
