All About Subs - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-13-2012, 03:49 PM Thread Starter
FordsNFishin's Avatar
All About Subs
In the middle of trying to figure out what subs to put in my truck. I've seen these extra shallow subs people have been making and was wondering if anyone has used them before and how they liked them??
They seem like the best option since they are only 3 1/2'' deep from the ones i've seen...Insanely small.
Any help on the choices i should check out would be appreciated. I am on a budget so cheaper is better.
I am planning on running 2x10'' subs, putting them under the seat of my extended cab.
If i have these two subs and say they each take 300 RHS, what all do i need to know in order to pick out a correct amp for it?
Thanks!! Here are a few links to the few subs i have been looking at.
Also, can someone explain the difference between a 2 and 4 ohm sub? What if i connect two of my 4 ohm subs to a 1 mono amp? Is that fine to do?
Rockford Fosgate R2SD2-12 Prime R2 Series 12" shallow subwoofer with dual 2-ohm voice coils at Crutchfield.com
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
^------This one says its a 400 RHS, so if i had two of these id prob need a pretty large amp to make them sound good wouldn't i? So buying these cheaper subs might not be the best bet?
Thanks
Bass, Walleye, Catfishin, an Trout. I'm tellin yuh now, you best look out! You were safe on the lakes, while i was home wishin. But be on yur guard, cause im goin FISHIN!
"Thats what I love about these high schools girls, I get older, and they stay the same age."
-2001 F-250 SD Extended Cab, Long bed 7.3 Turbo'd/Built 4r100 Tranny/DIY Intake/PHP 6 setting chip/ 4'' straight piped exhaust w/ 6'' tip.
FordsNFishin is offline
post #2 of 8 Old 03-16-2012, 07:45 PM
rjsoaz is offline
post #3 of 8 Old 03-18-2012, 08:41 PM
captivahach's Avatar
Thanks
Do yourself a favor and get the new rockford p3s alot better the r2 are junk
2000 F250, 6" bds,20'' kmc hoss with 37'' Xtreme AT's. 05 front,08 rear,S&B intake,4" proflow full exhaust,swamps custom tunes, swamps S/175/146 injectors,powerslots, hawks, ss brake lines,05 warn hubs, Pricol egt boost trans gauges ,Custom built tranny, low stall billet convertor, 38r, srp1
captivahach is offline
post #4 of 8 Old 03-18-2012, 08:57 PM
TheFordman87's Avatar
Thanks
Let me start by saying I have a setup for sale on here http://www.powerstroke.org/forum/int...sub-setup.html
But now let me tell you. If you bought two 4 ohm subs and had a mono amp better known as a class D amp. You can run them to a 2 ohm by running them as a series they way I had mine ran. Very simple if need be I can explain in full detail. Running 2 speakers that are a 2 ohm would only be a good idea if your amp can Handel 1 ohm but it's not that common. Ussually you have to spend a lot of money on a amp for it to be 1 ohm stable. 2 ohm subs would be ideal as well if you are going to run 4 subs but your not so let's move on.
The shallow subs are ideal for trucks but the thing is NO SUB is good unless it is in a good box with a decent amp playing it. Mainly it the box though.
Now let's say you want to play some subs that are 300 watts RMS you would need an amp the is at least 600x1 a class D amp (mono blocked) you could get one a little bigger but if budget is a big deal let's stick with the minimum.
So all of that being said if you have anymore questions feel free to ask.
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #5 of 8 Old 03-18-2012, 09:11 PM
doubledrop's Avatar
I run a single pioneer shallow 12" behind my rear seat right now and its great
I run in a ported box. but gonna go to 2 12's in a sealed box next
here is a very high level way to look at it
if u run 2 4ohms in series you will actually be at 2ohms. you would need to have an amp that is 2ohm capable (most decent amps are) so if you have 2 300RMS subs in series at 2ohms you would want an amp that puts out around 500-600RMS at 2ohms.
again that is VERY high level
doh! took too long to finally post and didnt see Fordmans entry.. so u get the info twice - haha
__________________________________________________ ______________________________
doubledrop is offline
post #6 of 8 Old 03-18-2012, 09:22 PM
Haha it's okay I'm sure he will appreciate it. Hey btw if your going to do 2 12's I would do them without a divider in the middle I'm a firm believe now cuz it's almost like each sub gets the whole box for air space makes them hit deeper and so on a so forth. Just food for thought.
post #7 of 8 Old 03-18-2012, 09:42 PM
doubledrop's Avatar
thats actually what i was thinking.. keeping it as a single enclosure for both
post #8 of 8 Old 03-18-2012, 09:47 PM
You will be more than happy trust me. I listened to a installer a fabricator that does and has done it for years and I was so glad I did.
