Over head display not working??!! help? - Ford Powerstroke Diesel Forum
Old 03-02-2012, 01:09 PM
I have a 2000 f250 supy duty with a 7.3 it got a little over 140,000 miles. when i bought the truck the overhead display that show outside temp, mpg, and direction. was working. now it dosen't. oh it will work if its below 30 deg. f outside. what should i do????
Old 03-02-2012, 02:42 PM
aussie=effie
Question help
mine has stopped working too ???
Old 03-02-2012, 02:55 PM
Mine is out right now too, it went out a while back and I took it down and plugged a resistor or something back in. I can't remember what was but it was clearly lose, I should have soldered it in while I had it out.
Old 03-02-2012, 03:05 PM
That's a common problem. A lot of times you can re-solder it and it works fine. But sometimes you have to get a new resistor or another board from a scarp truck.. Idk the size or type of resistor tho, but im pretty sure there was a thread on here or FTE that mentioned it..
Sent from my DROIDX using AutoGuide.com App
Old 03-02-2012, 03:10 PM
Yeah I have seen that thread on here somewhere, I'll probably have to get a new board haha. That's my luck.
Old 03-03-2012, 06:47 AM
i thought about resoldering it and even going to a junk yard, but honestly its not worth my time..
i found a guy on ebay that "rebuilds" them 29.99
sent it not working, drive around for a week with the overhead console sitting behind the back seat, readout showed up...reinstalled, reset the compass....good to go.
Old 03-03-2012, 12:05 PM
thanks guys! any body have a link to the thread on how to fix it? or a link to the ebay page for fixing it???
Old 03-03-2012, 12:25 PM
A few minutes isn't worth your time but 29.99 is?
Do some searching.
Here, I'll do it for you. I only charge 19.99.
Overhead computer Fix - Easy and it works
Old 03-03-2012, 01:06 PM
Do some searching.
for me yes.
if you need solder, and a soldering pen you have to purchase one not only does that account for $$ but its time also...
i have far too many things going on in everyday life to take the time to deal with the overhead unit.
track time with my kids, or changing oil on multiple bikes so we can go play is better spent to me that playing with and hoping it works.
sending it off to a guy that 100% positive feedback is fine by me...
as for what the OP asked for.
http://www.ebay.com/itm/FORD-SUPERDU...item3a6d78cdc6
http://www.ebay.com/itm/Superduty-Ov...item2569be5c89
Old 03-04-2012, 01:29 PM
Thanks for all the help guys i will take my down and see what i find and i will let you know how it goes!!
