Isspro EV2 install - Ford Powerstroke Diesel Forum
Old 02-13-2012, 04:59 PM
Isspro EV2 install
Im installing isspro gauges and need to work wire into the dimmer. Anyone know what wire into I should be tapping into?
Sent from my DROIDX using AutoGuide.com App
Old 02-14-2012, 06:36 AM
Back of the headlight sw.
Have you seen this page? -> http://stealth-automotive.com/docume...%20Install.pdf
Here's the thing though, you either just use the same wire that dims all the other dash lights (put a volt meter on the wire and "dial" the brightness up & down on the sw to see if the volts change to know you're on that wire) OR you use another dimmer with that wire (Isspro sells a kit) to "off-set" the factory dimmer. See, they use different kinds of light and, you might find the gauges too bright compared to the rest of the instruments. You could also experiment with resistors and put a 5cent piece in-line to save on using the Isspro kit.
Old 02-16-2012, 06:34 PM
The led backlighting is MUCH brighter than the dashboard. I found that if I dim the gauges to match, the led backlighting won't turn on if the gauges are really cold. A bit annoying.
Old 04-20-2012, 11:27 PM
I know its been a few months ago, how did it go? Any tips, I will be doing this job next week.
