Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
  #11 (permalink)
Old 10-18-2007, 07:27 PM
red73psd red73psd is offline
hell ya found my 680 was broken off
  #12 (permalink)
Old 10-18-2007, 08:52 PM
hell ya it works
  #13 (permalink)
Old 10-19-2007, 04:13 AM
quick26 quick26 is offline
does this correct the compas issue as well? my compas will stay blank and say cal underneath it. i calibrate it and the next day it does the same thing
  #14 (permalink)
Old 10-19-2007, 04:20 AM
Tree Killer Tree Killer is offline
Mine still works ; but atleast I found out how to remove it. For my cab light install project, THANKS
  #15 (permalink)
Old 10-19-2007, 09:25 AM
DGEM DGEM is offline
Just thought that I would mention this. When you take your overhead computer down to re-solder a loose chip, it is very worthwhile to go ahead and put a little solder on all of the 680 and 620 chip ends. If you don't, you will be probably having the same problem later on.
  #16 (permalink)
Old 11-06-2007, 03:52 PM
brian42 brian42 is offline
After seeing inside I can't believe Ford charges $185 for an o/h unit!
  #17 (permalink)
Old 11-06-2007, 08:27 PM
tell me about it
  #18 (permalink)
Old 11-13-2007, 06:04 PM
san-d-eggo san-d-eggo is offline
just did this to mine. works great
  #19 (permalink)
Old 11-15-2007, 12:49 PM
Kummok Kummok is offline
Works but still too dim for old eyes
Excellent fix! Wish my fingers were a little smaller but it works like a champ now! I'd like to keep the display lit to full brightness.....Anyone know which harness "wire to cut" to keep the display from dimming when the headlights are turned on?
  #20 (permalink)
Old 11-15-2007, 05:03 PM
Southpaw Southpaw is offline
1/20/2013
Originally Posted by sea71 View Post
Thanks for the info!! Sure it will come in handy for someone!! Not to hijack, but do ya have a fix for an o/h computer that works properly, EXCEPT for the miles to go part. It always starts around 900 or so and counts down. I cant reset, or I dont know how, but have read all I can and still cant get this part to work. Thanks again!!
Mine is the same way. IT IS SO ANNOYING. It depends on wether I park on ahill or flat ground. Sometimes my low fuel light comes on and I check it and it says like 250 miles to empty and it starts counting down like 4-5 miles every 1/2 mile I drive, like it's eventually going to coorect itself and be right on at 0.
If I park facing downhill, just the opposite. It will show 20 miles to empty when I have a 1/2 tank left and the number wont change, it stays at 20. I can't stand it. I would love to know how to fix this.
sorry for the
