Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
  #91 (permalink)
Old 08-24-2009, 03:28 PM
texasaggiesrocks texasaggiesrocks is offline
mine just went out last week, then found this thread. Works great now, thanks!
  #92 (permalink)
Old 08-25-2009, 01:53 PM
1faststang 1faststang is offline
WOW ! Thanks for the tip, It worked great. Popped mine off with no problems, and found 2 chips sticking up. Took less than 10 min total to fix and that included waiting for the soldering iron to heat up.
Here is what to look for.....
  #93 (permalink)
Old 10-23-2009, 09:16 AM
AhrmanHammer AhrmanHammer is offline
Send a message via Yahoo to AhrmanHammer
Thanks for the tips and pics... Just fixed mine, it only took a couple of minutes and it works great now.
  #94 (permalink)
Old 10-23-2009, 10:15 PM
99PSD-White 99PSD-White is online now
im in the process of fixing mine right now and looking at pics i found my circuit bored doesnt have the thing circled in the picture? Is that bad? what is it?
  #95 (permalink)
Old 10-23-2009, 10:18 PM
im not sure what that part is?
do you have chips that are popped up?
john
  #96 (permalink)
Old 10-23-2009, 10:28 PM
yeah i have 2 680s that fell out
  #97 (permalink)
Old 10-23-2009, 11:33 PM
well anyways i did a ****ty solders job on the 2 680s that broke off and pluged it back in my truck and BAM it works again. But it dims down a little bit and i have to smack it to light up normally. so i will take it out again when its not 3am and do a better solder job and get new resistors.
  #98 (permalink)
Old 10-26-2009, 02:37 PM
PSdiver34 PSdiver34 is offline
perfect, i was wondering how to fix this w/o paying for a new one!
  #99 (permalink)
Old 11-04-2009, 10:29 AM
Just did the fix on mine and it works perfectly again! thanks a lot guys
  #100 (permalink)
Old 11-04-2009, 03:16 PM
scraph scraph is offline
Hey man, good heads up on that one. I about tore into it the other day but didn't get any further than staring at the console exterior cross-eyed. All you had to was just pull on it, it's interior clips, and I was golden.
A suggestion, if no one else has considered it, is to put a dab of epoxy onto each SMD ... the chips and other things are not as likely to fall off ... but these SMD resistors could use a little make-shift conformal coating.
