Alarm chime problem - Ford Powerstroke Diesel Forum
Old 01-02-2012, 05:38 AM
Alarm chime problem
I have had this problem for some time now and have just been ignoring it even though it is irritatting. I think it is the key left in ignition alarm bell and it continues to chime as long as the driver's door is open - whether there is a key in the ignition or not. It only goes off when the ignition switch is turned on. Does anyone know how to cure this?
Old 01-02-2012, 07:21 AM
Take the steering column cover off under the steering wheel there are three screws, when you get it off look by the ignition switch there should be a wire I think its black I can't remember exactly but that is your chime wire its connected to the ignition by a metal connector I just disconnected it and taped it up really easy. On mine it was the only wire I saw going to the ignition. No more chime.
Sent from my ADR6350
Old 01-02-2012, 08:01 AM
Thanks much for the info... it will be nice to not hear that chime.
Old 01-02-2012, 08:37 AM
I had that problem after installing my remote start it just kept making that chime noise so glad its gone if you have any problems let me know.
Old 01-03-2012, 07:08 AM
Thanks I know what I'm doing soon! I can usually make my chime quit by fiddling w/ the switch but hell I'll just disconnect it lol
Old 01-03-2012, 08:55 AM
You think I am a liar buddy?
Tags
ntonkin@yahoo.com
