I got bored so look what I did today - Ford Powerstroke Diesel Forum
post #1 of 30 Old 01-15-2011, 07:15 PM Thread Starter
justinlogue5_0's Avatar
Well if you have seen my other threads you know I already put all my gauges in blue but it just wasn't enough
You know at night if you drop some thing on the floor and turn on the dome light you still can't see the floor
Well not any more!!
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #2 of 30 Old 01-15-2011, 07:50 PM
venturesomerite's Avatar
looking good, I did leds like that dash in my Dakota, was thinking about doing it to my 250. Your looks nice!
E99 SC LB 4x4 auto 7.3
Glow Shift gauges, pillar pod,column pod, Hutch, harpoon, 05 headlights,HPx, FRx, Napa Air Filter, 4" turbo back MBRP straight pipe,CCV, 1 ton crane on bumper, Reading flip top utility body, jersey bars, Modified/ strengthened Vangaurd Ladder rack, telescopic work lights, reverse facing flood lights, quad fogs
Future mods: on board air, inverter with outlets in bed
venturesomerite is offline
post #3 of 30 Old 01-15-2011, 07:53 PM
If I could change the overhead light out for a cool/bright white led and put the same color leds down on the floor and under the back seat like that...I'd be all over it. It sucks in there at night
e99f2506sp is offline
post #4 of 30 Old 01-15-2011, 07:59 PM Thread Starter
I found all the lights on ebay pretty cheap. I tied into the wiring that runs to the dome light. That way it all comes on with the door or light switch.It def wasn't that hard.
It never ends!
post #5 of 30 Old 01-15-2011, 08:01 PM
Which ones did you use?
post #6 of 30 Old 01-15-2011, 08:17 PM Thread Starter
Give me a second and I will find then for you.
It never ends!
post #7 of 30 Old 01-15-2011, 08:22 PM Thread Starter
I used this one for the dome.I used blue but if you go to his ebay store you can get all colors.
LED BLUE 2 PCS DOME MAP INTERIOR LIGHT BULBS hid FORD - eBay (item 150549350248 end time Jan-16-11 13:35:44 PST)
Same with these strips. I ordered two sets. One for the front and one for the back
LED BLUE 12" STRIP INTERIOR LIGHTS xenon hid FORD - eBay (item 200558761266 end time Jan-25-11 18:38:46 PST)
It never ends!
post #8 of 30 Old 01-15-2011, 08:41 PM
galla35's Avatar
looks good!
2000 f350 CC Lb 4x4 AT
airaid intake
ts 6 pos chip
foil delete
muffler ran away
leveling kit
4'' protech lift
315 bfg mud terrains km2s (undersized)
iss pro guages
galla35 is offline
post #9 of 30 Old 01-15-2011, 08:42 PM
Cool. Thanks man. I'll have to check into it
post #10 of 30 Old 01-15-2011, 09:04 PM
Beast Of Burden's Avatar
When you did your gauges did you have to use resistors or just get the colored LEDs and swap them out? The new lights look great too
2000 F-250 Reg. Cab Long Box, 4x4, Auto., 285/75/16 GY Dura Tracs,
1990 Mustang 5.0 LX hatchback, auto, Prowler orange. Car has full exhaust, E-cam, Trick Flow upper and lower intake, ADJ. fuel pressure reg, A/C delete, AOD with hardened shafts shift kit and TCI 3500 stall, not yet installed 3:73 gears, and TFS Twisted Wedge heads
Beast Of Burden is offline
