Broken Key FOB, where can I get a new one? - Ford Powerstroke Diesel Forum
Old 12-14-2010, 03:35 PM
My key FOB is a little broke...unfortunately it didn't fare well after my hubs wouldn't engage the other night and I was stuck in my own drive. (replacing those junkers with Warn ones asap) Problem is that I have no clue what type/brand it is and where the heck to get a new one. Ford parts guy says nope not stock! Best he could help was he said it appeared to be a Zenith (sp?). Has anyone seen this style key FOB and know the brand? Know where I can get one that will work? Thanks!
Old 12-15-2010, 11:19 AM
HELP!
So I tried the sequence to get in into program mode (8 key cycle one) and it after several attempts it would not go. So I went in search of the control box and this is what I found.....
Sure looks like stock to me, any ideas anyone? Would a cool down timer have an effect on it going into program mode? Any ideas would be helpful!
Old 12-15-2010, 11:23 AM
Have you asked your Ford guy if he knows what a PC-12 Module is?
Old 12-15-2010, 11:46 AM
No I have not, I will have to stop in again and ask.
Old 12-15-2010, 12:03 PM
Almostdunfukinwidit
Thats a stock Body control module
Old 12-15-2010, 12:19 PM
Do you know if there is another sequence to get it into program mode? Tried: Unlock all doors, close door, key in ignition, lock, unlock, 8 cycles of the key from off to run position. Also tried another one I read:
1. Get in close the door, hit the unlock button(all locks have to be in the same position)
2. Put the key in the ignition, turn the key from off position to the run position (not start) eight times VERY QUICKLY, ending in the run position.
3. The locks will automaticaly cycle on there own.
4. Hit the lock or unlock button on the keyless remote, and it will be programmed
Old 12-15-2010, 12:21 PM
Almostdunfukinwidit
The sequence is listed in your owners manual.
Old 12-15-2010, 01:05 PM
Just went out and reviewed the owners manual, performed that sequence several different times.....no joy. I'm at a loss, obviously something is not right......doesn't suprise me though, everything I have done to this thing since I bought it a few months ago has been a royal pain!
Old 12-15-2010, 03:43 PM
you gotta turn the key real fast,thats what i had to do
Old 12-15-2010, 08:12 PM
May be a silly question, but have you checked the battery in the fob?
