Dash Question - Ford Powerstroke Diesel Forum
Old 11-30-2010, 07:05 PM
Dash Question
I need to remove my dash board to get to my instrument panel cluster to change some light bulbs in there. My question is....do i just pull the plastic part of the dash off that is around the ipc, or do i have to undo some bolts? i know on the lower parts of the dash I have to remove bolts but not sure on the top piece.
Old 11-30-2010, 07:19 PM
The Tamed Racing Driver
Just pull.
Old 12-01-2010, 07:04 AM
Thanks for the quick response
Old 12-01-2010, 07:38 AM
Dont pull too far though until you remove the radio wiring and other wiring behind the dash. Everything should have a plug you need to disconnect then getting to the cluster is easy as can be.
Old 12-02-2010, 09:48 AM
Any luck on replacing the bulbs yet sullie
Old 12-02-2010, 06:50 PM
not yet. have not had the time to do it. but i will post on how it goes when i do it.
Old 12-08-2010, 08:58 PM
Ive got to replace mine also
Wish the bulbs would have already went out though cause I just had all that stuff off running a egt gauge to a column mount pod just last week.
Ive got a few behind the cluster and one being the heater/ac controls
