cruise not working? - Ford Powerstroke Diesel Forum
Old 11-21-2010, 04:59 PM
cruise not working?
my set/accl button isnt working how ever every other button works any ideas :/
Old 11-21-2010, 06:25 PM
Powerstroke Techie
If one button quits working and the rest of them work normally it is usually the buttons. They all run on 1 wire and just feed back different voltages to the pcm.
Old 11-23-2010, 02:44 PM
so how do you go about fixing it?
Old 11-23-2010, 03:39 PM
Powerstroke Techie
You need to disconnect the batteries for 10 minutes to disable the air bags, then remove the driver's air bag by removing the 2 plugs on the back of the steering wheel and then the 2 bolts that hold the air bag in. Then the switches will be able to be removed.
Old 11-24-2010, 12:03 PM
I had a similar problem awhile back, turned out it was my CPS.
Cruise Control
Should be some info and a pic in that thread.
Old 12-15-2010, 07:04 PM
i had the same problem, replaced the CPS and all is well
