Rear seat mod to fit bigger sub box - Ford Powerstroke Diesel Forum
Old 11-14-2010, 07:50 AM
I am posting this since I was asked a couple of times how I made my sub box fit into my truck . I didn't take any pics during the modification but it's really simple . You just turn the upper seat brackets around . Then install a spacer double the thickness of the factory spacer at the opposite end (toward back of truck) I also drilled new holes in my lower brackets as far forward as I could to get another inch or so forward . In the end the seat is about 2" further forward . I had a friend of mine who is about 6'4 sit in the back after the mod and he said it didn't feel too much different then his (he has the same truck) . Hear are some pics I took after the mod was done . If anyone has any questions let me know .
Rear seat mod to fit bigger sub box-074.jpg   Rear seat mod to fit bigger sub box-073.jpg   Rear seat mod to fit bigger sub box-072.jpg   Rear seat mod to fit bigger sub box-071.jpg   Rear seat mod to fit bigger sub box-097.jpg
Old 11-14-2010, 07:15 PM
looks awsome man. i have the same exact subs. there great. i swapped my brackets at first to fit mine behind the seat but i fount it was harder than hell to get your feet in the truck. so. i flipped my brackets back to factory and then just drilled the holes 1 inch further which gave me enough room for the subs but yet keep my foot room back there. i dont have a sweet amp rack like you tho
Old 11-19-2010, 10:20 AM
Chapter Director
about how much room do you have back there? ive got a sub thats too deep to build a box back there now but if i get a couple inches it may work
Old 11-19-2010, 01:30 PM
Yea it definitely cut down the walkway area getting into the truck but it's not to bad . There is 6.5 " between the front of the seat and the center pillar . As far as the room behind the seat I have a full 10" at the bottom and 6" at the top and this is with the carpeted panel still in place . The amp rack is a really easy piece to make . Also I turned the drivers side sub the right way too . It was a very late night when I put it in that way .
Old 11-19-2010, 01:41 PM
Very clean install, great job.
Old 11-19-2010, 01:45 PM
Thanks , I am pretty happy with it . It sounds great too .
Old 11-19-2010, 02:03 PM
Chapter Director
hmmm thats plenty of room ill have to take my seat out and play with measurements to get the most room for seating and the most airspace for a box
Old 03-09-2012, 08:05 PM
Nice setup
Old 03-10-2012, 08:05 PM
Thanks , I am really happy with it .
