i would take the door panel off and watch the track while you try to roll it down to make sure everything went back in properly and is lubed.then look at the motor.make sure its not hanging up on any wires
Man, I thought mine was slow.
My driver's side is slow, and while the passenger side isn't too slow, sometimes it doesn't work. I've discovered that if I open and slam the door shut while holding down the switch, it'll jolt the motor into working. You probably just need a new motor.
zaair- ford has a known problem with their window switches, i would start there first for the not working part of the problem.
Ripped the door panel off and am getting power to the motor. It's the motor itself (on the passenger side, at least). I'm guessing that CanadaDiesel's "new" 08 door sat open and unprotected in a junk yard for awhile, which is why the window isn't working so well. |
very possible
Thanks for the tips guys! Gonna try to tear into it on the wknd. During the week is too busy and the nights here are freaking cold.....winter is coming........
The front track on mine was broken in half, and the spot welds that hold on the mounting brackets where broken off also. I welded it all back together and the window works great.
Tom |
