No Dome, Map, or Cargo lights
I checked the fuse ( Position #14, 10 amp) and it still looks good, what else should I check?
Just found out the power windows dont work either. What the heck is going on with this thing?
Test all of your fuses . Use a voltage tester . Just looking at them isn't enough , you can't always see a blown fuse .
You are right, I replaced the fuse with one from another spot in the fuse box and everything works now, thanks buddy
No problem , I didn't even break a sweat
. Just glad it was an easy one for you . Electrical bugs can be a mess .
Same here. I hate electrical problems
