tilt wheel lever removal
how do i remove the tilt wheel lever from the steering column? it looks like i have to remove it in order to take the steering column cover off. i would like to replace my turn signal lever. it is worn and keeps cancelling on me early after any little movement of the wheel.
The tilt lever just unthreads like a normal bolt. I havent changed a turn signal switch, I would assume once you get the column cover off there would be four bolts and an electrical connector or two
thanks. it looks like it just unscrews, but i cant get it to move at all..... i guess i will have to find a way to vice grip it without damaging the plastic end.
I would grip it on the metal shaft as close to the column as possible, and hope the little tab that it threads into doesnt break. Good luck
ha ha ha, that would be my luck.....
There is a flat part that I think a 7 or 8 mm wrench will fit on at the base of it.
It unscrews, after you break it loose it will unscrew by hand. I have had mine off numerous times.
But last time I had the column cover off I did not have to remove it. Just remove the 4 screws that hold the cover on. The switch is held in place by 4 torx head screws. I believe they are T-10 torx head. Then you have one electric plug. Why are you replacing the switch |
because the switch is starting to cancel early. and sometimes if the wheel is turned a certain amount, it will not stay locked in.
It looks like some sort of loctite was used from the factory for the tilt lever. You will break it free eventually.
after looking at it closer, and with the helpful insight of another member
