Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 06-06-2007, 08:49 AM
late4sho late4sho is offline
Super Cab Rear Door
Hey guy's, I got some new speakers coming for my truck, and i know how to take off my front door panels but i don't know about my rear panels. Any input would be great.
Thanks
Old 06-06-2007, 08:53 AM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
Well the stock rear speakers are in the D-pillar, or the rear corners of the truck. They are not in the doors. I do not even know if there is a spot on the rear doors for speakers. You will have to run your own wire for them too.
But to my knowledge the panels just pop on with clips just be careful because if those clips break the door panel will not secure back on nice and tight again.
Old 06-20-2007, 12:00 AM
daboostcreep daboostcreep is offline
Say What? My 99 has speakers in the rear half doors! Factory. To remove rear door panels, undo screws that hold window latch to door, then simply pop the plastic panel off the door. The lower part of the door is covered by a second panel that is only removable once the top is taken off, and the removal points are very clear from that point on. Good luck!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
