How to remove headlight switch panel?
Hey
I have a 00 F250 and I'm putting some fog lights on. I want to run the switch to the headlight panel (to the right of the roll knob dim control). How do I pop off the little cover? I just dont want to break it. Thanks Fos |
I believe you gentle pry it out with a flat head. There is a little indentation where you can safely put a flat head in... Dont quote me on this but I believe thats it
so, question for those that have installed fog lights. i hooked a harness with relay and fuse and powered it directly to the battery. the fuse is blowing every time - tried the regular 15 amp and then tried 30 amp with same result. any idea where i should hook it up to or what could be my problem?
Do you have wires mixed up. either on the relay or on the ends.... If you have your ground with power on it and do the same to your hot wire blows the fuse... I would double check your wiring...
