Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 05-27-2007, 02:53 PM
scpbmxer01 scpbmxer01 is offline
back seat sub box
Anyone Have Pics Or Demsions For A Sub Box To Go Under The Back Seat I Would Like To Make One Myself Just Wanted To Know If Anyone Has Plans For A Box. Crew Cab.
Old 05-27-2007, 03:04 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
their is no room to put subs under the rear seats.... youll have to but them behind the seat... i got a pic of mine in my garage... you can also buy the stealth box from JL Audio....
Old 05-27-2007, 03:11 PM
04Harley 04Harley is offline
Along the lines of above. You could pull the rack and fit your amp under there, but no dice on the sub. And when you go to pick a sub, keep it as shallow as possible. I know kicker makes a new shallow type sub that will fit and sounds really good back there, ill try to find the plans for 2 10"s.
Ive got the captains chairs in the back so i went with a homemade JL audio stealth type box in my rear console rather that the front, it was the only way i could fit a deep 10".
Maybe blaupunkt makes a good shallow sub too now that i think about it, pioneer too.
Old 05-27-2007, 03:23 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
no room under seat for subs. You can try the above mentioned for a sub box or make your own. depending on the speakers (air space needed) I can give you dimensions on mine.
Old 05-27-2007, 03:52 PM
scogginSStroker35 scogginSStroker35 is offline
What about under the back seat in an extended cab obs.
Old 05-27-2007, 04:52 PM
Cj Ford Cj Ford is online now
mine is sitting on the rear seat.. you can still put 1 person back there if you slide it to the one side.. or pull it out its easy enough
Old 05-27-2007, 05:13 PM
Pioneer dual voice coil 10's 400w each 1000W Kenwood excelon amp
this stuff was all in my GTP I had to make it fit in the superduty
Old 05-27-2007, 05:18 PM
Patrick Patrick is offline
Send a message via MSN to Patrick
wow CJ, what you need all that for? lol
Old 05-27-2007, 05:20 PM
I want a small box for my extended cab. directly behind the center console, as wide as the center console (maybe a little wider), and just as high. Who wants to make it? lol Should be enough room for 1 10" facing up I think.
Old 05-27-2007, 05:58 PM
lets just say I like my music....
And I like it really loud it sounds awesome with that set up and the 6 1/2" Pioneer premier door speakers up front and the Pioneer premier 6x9's in the rear doors ... you can hear it loud and clear
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
